Sending checkpoint messages to VSM clients has failed. In such a case, CM's MLAG mode functionality will not function properly.
This is a rare condition which may be related to software, and may require a reboot of the switch to correct the problem. If it persists, contact technical support and provide outputs of 'show switch', 'show log'.
Error
Failed to send checkpoint messages to VSM clients. ISC ID map %peerIscIdxMap%, Return Code = %rc%, Length = %len%
Name | Type |
peerIscIdxMap | uInt16 |
rc | sInt32 |
len | uInt32 |
